hi, velleman;
i assembled my k8061 2 weeks ago. it is working fine with the demok8061. i have the following problems looking for answers:-
- does the k8061.dll work with visual foxpro 9.0(vfp9) which is very similar to visual basic 6.0?
- how to contain/show the return value(longint) as instructed in the manual. i tried on a text box by click event with codes as follows:
declare integer opendevice in k8061.dll as longint
thisform.label8.caption=longint
result: program error variable 'longint' is not found
another set of codes:
declare integer opendevice in k8061.dll as cardaddress
declare integer powergood in k8061.dll as boolean
if messagebox("do you want to close device?",4+32,"system notice")=6
declare integer closedevice in k8061.dll
thisform.init
else
thisform.init
endif
thisform.init
i expect a -1 and a T to be posted in the text box. the codes seem to be running but i cannot detect any response from the card.
do you have any advice for this?
regards.
from kit
