K8061 1 LED broken and "RUN"-LED blinking
Hi there,
thank you for the helpful contributions in this forum. I hope someone can help me, too.
I have 2 problems with the Interface I’ve just finished soldering:
  1. Unfortunately, one LED in my K8061 KIT is broken. What LED do I need to replace it (V and mA)?
  2. When I connect the card with power supply (in fact I had no 12V power supply so I used a 9V battery), LED 1-8 (LD 13-20) glow constantly but the “RUN”-LED (LD12) is blinking and not glowing constantly. Does that denote an error? What does this mean?
Unwary, I left out “Power ON”-LED (LD10). When connecting it to the PC Demo and Diagnosis say “USB connected” but “CPU FAIL”. I’ve uploaded a photo for it might help you helping me;-) fotos-hochladen.net/view/img … b6814k.jpg it is huge though.
Thank you for your support in advance.
Tim
I don’t want to offend but your soldering needs some help.
You need to resolder all of the joints so the pad is covered and the solder flows.
A 9 volt battery will not work you should get a 12 volt power supply that can provide 300mA or above.
Here some similar cases and solutions:
viewtopic.php?f=3&t=8949
viewtopic.php?f=3&t=9638
viewtopic.php?f=3&t=5456
viewtopic.php?f=3&t=7505
viewtopic.php?f=3&t=4098
viewtopic.php?f=3&t=2476
viewtopic.php?f=3&t=4151
