If the thermal specs are equal or better, they can be used.
A couple of hints:
Leave the power transistors on the board, do not remove them from the board, to avoid oscillation.
Make sure the transistor and diode that serve as thermal sensor make proper thermal contact with the heatsink, but watch out for short circuits.
