K8060
I bought the kit a while ago, over a year ago, and despite the warnings in the instructions managed to get some of the transistors mixed up. I re-bought a set of transistors to replace all the transistors on the board as suggested in your forum. Unfortunately even after checking several times that the transistors were correct this time the board would still not work and now several of the solder tracks have lifted. In disgust I put the kit on a shelf and there it has sat till now. Do you offer a repair service where I could send my board to be repaired and if so how much does it cost? My only other alternative is to buy a new kit but it annoys me to waste the kit I already have.
We can offer repair, but if the PCB is damaged it will need to be replaced so it will be cheaper to get a new kit and use the kit parts as spare parts.
Thank you, that’s what I’ll do.
