Hi, i have a problem testing the K8060 kit.
When i turn on the power the resistors R19 & R20 and the transistors T7 & T8 are getting hot in less than a second,
also the Transformer gets warm. 1A Fuses between the Transformer and the power supply are melting (1,6A not).
A measurement on R19 shows me ~200 mV. The LED lights. The bias is fully turned left.
I am using the RKT120.30 2x30V 2x2A Transformer. http://www.reichelt.de/Ringkerntrafos/RKT-12030/3//index.html?ACTION=3&GROUPID=3321&ARTICLE=15265&SHOW=1&OFFSET=16&
The data sheet on it says: Sek1: Red-Yellow, Sek2: Blue-Green; and i have ~32V on each.
Between Red & Blue i measure ~3V and the same between Green & Yellow.
So i put Red on AC+, Yellow on AC-0 and on the other side Blue on + and Green on 0 (As u see in the picture below).
When i switch red with yellow and blue with green the error remains.
I first thought there must be a bridge between solders where it shouldnt be so i checked all solderings multiple times and all looked good.
Then i checked the transistor postions. All at the right place and right direction. The hole assebly seems to be right.
I just cannot find the problem. Do you have any ideas ?
Amp + Transformer: http://www.fotos-hochladen.net/uploads/20140521174wonth9sml2.jpg
Amp Solderings: http://www.fotos-hochladen.net/uploads/201405211742b7p51xrjt.jpg
Amp Assembly: http://www.fotos-hochladen.net/uploads/201405211749pcevu2bio.jpg
