K8058 stays silence
Build a K8056, and used the test switch to see that all the relais are working.
Then building the K8058, something do not seem to work. Pushing the buttons light up the LED but no relais was working. So I pushed the Shift, used 3 to see that de LED flaches three times, then used 4 but de LED just flashed, and nothing happend. Is it possible that there is something wrong with the handheld ?
Is your K8056 equipped with the RX433 receiver module ?
Did you select wireless instead of RS232 ?
Did you select ‘remote control on’ ?
Read K8058 instructions carefully. Try using the option ‘force card to address 1’.
If problem persists, return kit(s) for inspection/repair.
