K8056 with remote control
I have a problem with a remote control K8058.
I’ll try to explain what is my problem.
I bought 3 kits: (K8056+ RX433N+K8058)
The first 2 kits I mounted are working very properly. But the 3rd isn’t working with remote control.
If I try an other remote control the 3rd K8056 is working. I also tried the other way, If I try the last mounted K8058 with an other K8056, that one isn’t responding. So I’m pretty sure there’s a problem with the remote control and not with the remote relay card.
Afterwards I tried to force this remote control to adress line 1 by pushing shift untill the led lights up and then I pushed the 4 but nothing is responding…
Can I still try something else?
On the remote relay card the jumpers are set like this: JP1 : remote
JP2: normal
JP3: on
If you would like me to check anything, you can let me know, I have an osciloscope and multimeter if necessary.
I already measured on the antenne while pushing any button and there is signal coming out… :open_mouth:
On the receiver isn’t coming anything in on the antenna. :angry:
Pls let me know what to do. :wink:
Does the led of the remote blink when a button is pushed ?
Does the receiving led on the K8056 blink when the remote is operated.
If it does, but the relays do not operate, then there is an address problem.
If not, check remote data speed and compare with two other remotes. Maybe PIC internal oscillator is off-spec.
[quote=“VEL417”]Does the led of the remote blink when a button is pushed ?
If not, check remote data speed and compare with two other remotes. Maybe PIC internal oscillator is off-spec.[/quote]
Dear sir,
The LED of the remote does blinks when a button is pushed, but the data led situated on the board of the K8056 isn’t responding while pushing on a button between 1…8.
Ive measured the signal once more at the antenna of the remote control while pushing a button and seems 2 be about 9ms duration (111Hz) (see picture)
Unfortunatly I can’t compare the signals anymore with an other remote control because yesterday we already delivered the other 2 to the customer. :frowning:
Sorry, but this information does not allow us to locate the source of troubles.
We suggest you return the K8058 for examination.
Return it to your Velleman distributor or to:
Velleman Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
[quote=“VEL417”]Sorry, but this information does not allow us to locate the source of troubles.
Legen Heirweg 33
9890 Gavere
Belgium[/quote]
OK, I will send it directly to you in Gavere. The remote control will leave this evening from Brussels. :wink:
Can you please keep me in touch about what’s going wrong?
Thanks in advance,
Philippe
hi i assemble the kits K8056 and adding the RX433N and then assemble the remote transmitter k8058
the led’s on the transmitter working according to the manual but in the relay card only the power led is on the data led never go on
the voltage are ok and the jumpers are in the position for RF and remote
is press the push button for test all the relays working fine
Have any suggestion for make more test and fine the problem
Did you pair the remote and the relay board?
You can find the instructions in the manual for the remote.
I read the set up and I press the shift and hold until the led is on and the press 2 for see the address but the led in the relay board don’t go on and then try to force to address 1
press the shift and then 4 but occurs the same the led is not on
Could you post some Very Sharp and Clear pictures of the top and bottom of the board?
Hi I have the pictures but I can’t paste here the pictures in the normal format do you have some mail where I can sending it??
Here are the pictures
imageshack.com/a/img845/4618/wvz5.jpg
imageshack.com/a/img822/8413/mq2as.jpg
How are you powering the K8058 Voltage, Current, AC or DC?
Hi, I used a 24 vac, 2 amps for powered the k8056 board
sorry, I wirte the wrong answer, I used a 12 vac transformer with 2 amps, the power led is on when connect the transformer and all the relays working one by one when press the test butom, and the output power generated by the card is close to 14 vdc non regulated, ans also I was testing the voltage in the RF voltage and is 5 vdc
A couple of solderings might need some rework.
Can you check with a multimeter or scope if the data from the receiver arrives at the PIC (see diagram in manual for pinout).
If it arrives, then most likely the remote is not correctly configured.
