K8056 + k8058
I have a k8056, k8058 and RX433. I mounted it and nothing happens. When i push the test button on the board, all channels turn on and off. When i push the remote control the led inn the remote control flashes but the board doesn’t do anything, not even the data led flashes. The power led is on. I tryed to force the remote and receiver to the same channel, but nothing changed. I don’t no if it worked or if there is something wrong.
Do you have any suggestions what to do now?
Did you mount the jumper on the K8056 for remote on ?
Did you mount the jumper for wireless control instead of RS232?
Yes, I did mount both the jumpers and nothing works. I mounted a wire as antenne and that 'makes no changes.
if you have an oscilloscope, you could check and see if RX signals from RX433 are present.
If not, we’d recommend you return both kits for inspection/repair.
I have an ascilloscope and connected it to pin 2 and ground. When I push a button on the remote, there is no signal on RX433.
What is the adress to both kits for inspection/repair.
Most likely, there is a problem with the remote K8058.
You can return it to your dealer or to:
Velleman Projects Tech. Dept.
Legen Heirweg 33
9890 Gavere
Belgium
US residents: Please call (817) 284 7785 for RMA#
