K8055N Digital Outputs
Hello community,
I bought the K8055 yesterday…
I finish the building and want to test all in/outputs…
All inputs work fine, analog outputs work fine but the digital outputs dont work(the system LED work fine).
All digitaloutputs are at no cross = 0.
If i conect a extern LED to output 1 (-) and the (+) to DAC2 output the LED switch on and i could not switch off the LED.
If i switch output 1 to on the system LED switch on so i think the IC work fine.
How can i fix it?
sry 4 my english…
The digital outputs of the K8055 are open collector. Do you know what that means?
Regards,
Jan
