k8055D.dll source code or 64-bit release of the .dll?
[quote=“theo22”][quote=“Ghislain_B”]
Does the license of your code allow to distribute it freely, like MostlyHarmless’ ? I guess yes, it’s probably not limited to this site.
Also, will the link remain valid ? If not, is there a better choice ?[/quote]
I don’t care about the license.
I’m not going to delete the link soon, but a copy of the files somewhere at velleman.eu would be nice.[/quote]
The question would be did you write that code from scratch yourself, or did you take the original Velleman Pascal code and compile it with a 64 bit compiler? If it is the latter, then you have no choice, the code is under whatever license Velleman originally published it. If you wrote it yourself, then you should make a decision about a license. Or declare it to be in the public domain.
For something like this, LGPL or BSD would probably be the most appropriate.
Regards,
Jan
I’d say the DLL has the same license as the DLL here: box.com/s/rindcmazr586ofistubh
If Velleman wants me to remove the link to the 64bit DLL because of license problems, I will do this asap.
Digging this up again…
I am currently using the v5.0.0.1 K8055D.dll. Is an x64 version available? Can anyone make one? I’m using C#/.NET for my application.
