K8055 - Windows 7
I have to use a K8055 for my studies.
The problem I have is that I have to work on a Windows 7 system, but I don’t have software for this.
Does any software-update or new software exist to use it with Windows 7?
The K8055 is compatible with Windows 7. It is a HID device, just like a mouse or keyboard so it does not even require a special driver.
What exactly is the problem?
Available downloads:
velleman.eu/support/downloads/?code=K8055
The problem is, that I can’t use the software on a 32bit Windows 7 version. There is a fault indication when I want to use the test software.
On a 64bit version I can’t even find the K8055.
I want to creat a small new program with Delphi and therefor I want to use the dll.
[quote=“Doktr90”]There is a fault indication when I want to use the test software.[/quote]What fault indication would that be?
[quote]On a 64bit version I can’t even find the K8055.[/quote]Where have you looked, what have you tried?
Please be more specific
I have just tested the card and it works without the least bit of trouble
Windows 7 32-bit Device Manager (devmgmt.msc)
K8055_Demo.exe under Windows 7 32-bit
