K8055 WIN7 VB.NET 4 VisualBasic 2010
Hallo, Sorry i dont speak english, and i try:
I have K8055 and use this with VB6 on WIN XP this is verry easy and good!!!
Now i have new system with WIN7 VB.2010 on 64bit
The example for .Net its not usual
Error with DLL
Have you a new dll for my system???
thank you
Jason
No need for a new DLL. Just use the v3.0.2 from this downloads page:
velleman.eu/distributor/supp … 8055&type=
If you get this error message:
[color=#800000]An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)[/color]
Then you have to do this:
[color=#000080]Select Tools / Options / Projects and Solutions / General
Check the ‘Show advanced build configurations’ check box.
Then select the menu option: Build / Configuration Manager
In the column ‘Platform’ select <new…>
To the ‘New platform’ select x86
Now go to menu Project / Properties… There under the Compile and Debug tabs there should be ‘Active (x86)’
Now you can compile the K8055 demo.[/color]
Here a link to download the Visual Basic 2008 Express example project: box.net/shared/euf9bd2rc4
WONDERFUL … THANK YOU
Now is EASY to use in my new contellation
:laughing:
BIG BIG THanks
