The LD8 flashes indicate that the PIC microcontroller is running but the USB connection (enumeration) fails.
There may be several reasons to this problem.
You may find some hints from this thread:
If you have other USB devices connected to the PC, you may try removing them (if possible).
Also DirectX may cause some compatibility problems if used.
