K8055 Thermistor project
hi, i need a simple circuit / code to anaylise the temperature from a thermisor, i have a few simple ones here, “ttc 102”, one that just says “10 - 25 ++” and also a green ‘pill’ like thermistor. does anyone have a code that can get the temp from the thermistor, and display in a text caption. Any help will be grateful. Thank you. :smiley:
Wrong Way: that program worked, i get readings but they don’t seem to be right :confused: have you got any suggestions? thanks for the reply.
I don’t know if this will fit your application but maybe the K8067 would work for you.
You can see more information at the link below.
http://www.vellemanusa.com/us/enu/product/view/?id=521726
Also in the software download section there is a demo package for the K8067 to connect to the K8055.
The link for the download section is below.
http://www.vellemanusa.com/us/enu/download/files/
It’s about 3/4 down the page.
As always I hope this helps.
