Private Sub Timer2_Tick(ByVal Timer2 As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick
If Timer2 = False Then
SetDigitalChannel(1) = False
ElseIf Timer2 = True Then
SetDigitalChannel(1) = True
End If
End Sub
whats wrong with this??
i have the :
Private Declare Sub SetDigitalChannel Lib "k8055d.dll" (ByVal Channel As Integer)
at the top of the page …
sorry i have 2 books im reading too
Here an example how you get a blinking LED.
The digital channel is on for one second and then off for 500ms etc.
You may extend the state machine by adding steps.
You may test this using the example in the folder \examples\K8055DemoVB_2008.
Just replacing the timer 2 handler code with this one and add a public variable “state” to the declarations section of the code.
Dim state As Integer
Private Sub Timer2_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer2.Tick
Select Case state
Case 0
Timer2.Interval = 1000
state = 1
Case 1
ClearDigitalChannel(1)
Timer2.Interval = 500
state = 0
End Select
End Sub
In the program click the “Output Test” button to run this example.
so if i wanted it to blink every 30 seconds for a second of two,
i would call intivals 60000 and 30000??? and set the intival on the form designer to 100???
Option Explicit On
Public Class Form1
Private Declare Function OpenDevice Lib "k8055d.dll" (ByVal CardAddress As Integer) As Integer
Private Declare Sub CloseDevice Lib "k8055d.dll" ()
Private Declare Function Version Lib "k8055d.dll" () As Integer
Private Declare Function SearchDevices Lib "k8055d.dll" () As Integer
Private Declare Function SetCurrentDevice Lib "k8055d.dll" (ByVal CardAddress As Integer) As Integer
Private Declare Function ReadAnalogChannel Lib "k8055d.dll" (ByVal Channel As Integer) As Integer
Private Declare Sub ReadAllAnalog Lib "k8055d.dll" (ByRef Data1 As Integer, ByRef Data2 As Integer)
Private Declare Sub OutputAnalogChannel Lib "k8055d.dll" (ByVal Channel As Integer, ByVal Data As Integer)
Private Declare Sub OutputAllAnalog Lib "k8055d.dll" (ByVal Data1 As Integer, ByVal Data2 As Integer)
Private Declare Sub ClearAnalogChannel Lib "k8055d.dll" (ByVal Channel As Integer)
Private Declare Sub SetAllAnalog Lib "k8055d.dll" ()
Private Declare Sub ClearAllAnalog Lib "k8055d.dll" ()
Private Declare Sub SetAnalogChannel Lib "k8055d.dll" (ByVal Channel As Integer)
Private Declare Sub WriteAllDigital Lib "k8055d.dll" (ByVal Data As Integer)
Private Declare Sub ClearDigitalChannel Lib "k8055d.dll" (ByVal Channel As Integer)
Private Declare Sub ClearAllDigital Lib "k8055d.dll" ()
Private Declare Sub SetAllDigital Lib "k8055d.dll" ()
Private Declare Function ReadDigitalChannel Lib "k8055d.dll" (ByVal Channel As Integer) As Boolean
Private Declare Function ReadAllDigital Lib "k8055d.dll" () As Integer
Private Declare Function ReadCounter Lib "k8055d.dll" (ByVal CounterNr As Integer) As Integer
Private Declare Sub ResetCounter Lib "k8055d.dll" (ByVal CounterNr As Integer)
Private Declare Sub SetCounterDebounceTime Lib "k8055d.dll" (ByVal CounterNr As Integer, ByVal
DebounceTime As Integer)
Dim i As Integer
Private Sub CheckBox3_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckBox3.CheckedChanged
i = ReadAllDigital
CheckBox4.Checked = (i And 1) > 0
CheckBox5.Checked = (i And 2) > 0
CheckBox6.Checked = (i And 4) > 0
CheckBox7.Checked = (i And <img src="/uploads/default/original/1X/77285d5b171a9185455b287d7dac6638c76b3ea8.gif" width="15" height="17" alt="8)" title="Cool"/> > 0
CheckBox8.Checked = (i And 16) > 0
End Sub
Select Case state
Case 0
Timer2.Interval = 30000
state = 1
Case 1
Timer2.Interval = 60000
state = 0
End Select
End Sub
Private Sub Button3_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button3.Click
Dim h As Long
Dim CardAddress As Long
CardAddress = 0
CardAddress = 3 - (CheckBox1.Value + CheckBox2.value * 2)
h = OpenDevice(CardAddress)
Select Case h
Case 0, 1, 2, 3
label2.Text ='Card '+ inttostr(h)+' connected';
Case -1
label1.Text ='Card '+ inttostr(CardAddr)+' not found';
End Select
End Sub
Using this code the LED is on for 2 seconds and off for 30 seconds:
Select Case state
Case 0
Timer2.Interval = 2000
state = 1
Case 1
state = 0
End Select
End Sub
You may add to the CheckBox3 code this lines to turn the timer on by pressing the “Output Test” button down:
If CheckBox3.Checked Then
Timer2.Enabled = True
Else
Timer2.Enabled = False
[quote]isnt channel itself an array ??? one number beeing the address and the opther being its state[/quote]No, here is the channel number the only parameter. There are different functions to set and clear the channel:
SetDigitalChannel(1) 'channel #1 ON
SetDigitalChannel(5) 'channel #5 ON
ClearDigitalChannel(1) 'channel #1 OFF
ClearDigitalChannel(5) 'channel #5 OFF
Please see the manual for more details how to use the other functions too, e.g.
WriteAllDigital.
J’ai fais un programme recuperant le nombre de flacon en fonction du temps sur excel en visual basic avec la digital input 1 du VM110 de plus j’ai programmé une sauvegarde automatique avec aussi une creation et changement de fichier chaque jours
pourriez vous m’aider à corriger les erreurs de programmations svp
'/PREMIER CAPTEUR /////////////////////////////
'Je lance le programme au démarrage
'Lancer un programme au démarrage du PC -> Sans toucher au registre( menu Démarrer )
Private Declare Function SetTimer Lib "user32" ( _
ByVal HWnd As Long, ByVal nIDEvent As Long, _
ByVal uElapse As Long, ByVal lpTimerFunc As Long)
Private Declare Function KillTimer Lib "user32" ( _
ByVal HWnd As Long, ByVal nIDEvent As Long)
Private Declare Function OpenDevice Lib "K8055D.DLL" (ByVal CardAddress As Long)
Private Declare Function ReadAllDigital Lib "K8055D.DLL" ()
Private Declare Function ReadIOchannel Lib "K8055D.DLL" (ByVal Channel As Long)
Dim TimerID As Long
Dim TimerSeconds As Single
Dim Connected As Boolean
Module Module1
Sub Main()
'Initialisation des variables
Dim Byt As Long
Byt = ReadIOchannel(1)
Dim Date_jour As Date
Dim heure As Date
Dim N As Integer
N = 0
'Boucle infinie /!\
While 1
'Récupération de la date actuelle
Date_jour = Date_jour.ToShortDateString 'je recupere que jour/moi/année
heure = heure.ToLongTimeString 'je recupere que heure/min/sec
'/////// TEST CHANGEMENT DE JOUR ///////////////////////////////////
If Date_jour <> Worksheets("Production en cours 1").Cells(N, 3).Value Then
'creer nouveau classeur
Dim D As String
D = Day(Now) & Month(Now) & Year(Now) & "_" & Hour(Now) & Minute(Now)
Workbooks.Add
ChDir "C:\Documents and Settings\moi\Bureau"
ActiveWorkbook.SaveAs Filename:= _
"C:\Documents and Settings\moi\Bureau\Production en cours 1_" & D & ".xlsx", _
FileFormat:=xlOpenXMLWorkbook, CreateBackup:=False
'/////// DEFINITON DES COLONNES ///////////////////////////////////
'On nomme les colonnes
Range("A1").Select
ActiveCell.FormulaR1C1 = "Nombre de Flacon"
Range("A2").Select
Columns("A:A").ColumnWidth = 16.71
Range("B1").Select
ActiveCell.FormulaR1C1 = "Heure"
Range("C1").Select
ActiveCell.FormulaR1C1 = "Date"
Range("C2").Select
'/////////////LES VARIABLES ///////////////////////////////////
Dim nb_flacon As Integer
nb_flacon = 1
'/////////Remplissage du tableau ///////////////////////////////////
' Remplir 3 colonnes : une disant le nombre de flacon et une les jours et l'autre les heures
If (Byt = 1) Then
' prévoir un anti rebond avec détection de front descendant
ActiveSheet.Cells(N, 1).Value = nb_flacon
'j'incremente mon nombre de flacon
nb_flacon = nb_flacon + 1
ActiveSheet.Cells(N, 2).Value = heure
ActiveSheet.Cells(N, 3).Value = Date_jour
'j'avance d'une ligne
N = N + 1
'////// Function sauvegarder ///////////////////////////////////////
'pour sauvegarder tout les 100 flacons
Dim Save As String
Save = nb_flacon / 100
'Save : valeur booléen. Vrai si c'est un entier, faux sinon.
Function Entier(ByVal Save) As Boolean
Entier = Int(Save) = Save
End Function
If Save = 1 Then
ActiveWorkbook.Save
End If
End If
Else
'///////////CHANGEMENT DE JOUR ///////////////////////////////////
' Subtract one day.
Dim today As DateTime
Dim Yesterday As DateTime
today = System.DateTime.today
Yesterday = today.AddDays(-1)
' Write the yesterday value.
"C:\Documents and Settings\moi\Bureau\Production flacon 1_" & Yesterday & ".xlsx", _
End Function
End Sub
