K8055 program
hai,
I now have my K8055 at home but i dont understand the programing. Can someone do the following (in visual basic). So i can look to it and puzzel whit it and make my one program.
if input 1 is true give output 1
if input 1 and 2 are true give output 2(no output 1)
Dim i As Long Dim n As Long i = ReadAllDigital If (i = 1) Then n = 1 ElseIf (i = 3) Then n = 2 Else n = 0 End If WriteAllDigital (n)
You can add this code to the Private Sub Timer1_Timer() procedure in the VB6 example.
In Visual Basic 2008 Express to this:
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
thanks for the fast reaction but can you explain the 3 in ElseIf (i = 3) Then becaus i see if i change it to 4 then inpout 1 is outpout 1 and inpout 3(only) is outpout 2
and the n = 2 becaus if 1 change it to 3 led1 and 2 are burning and if i change it to 10 led 2 and 4 burn what is the idee behinde this
You have to convert the values to binary.
0000 0001 = 1
0000 0010 = 2
0000 0011 = 3
0000 0100 = 4
0000 1000 = 8
0000 1010 = 10
1111 1111 = 255
and how can i use it whitout timer 1 in my project
You may attach the code to a button.
you can make it whit Private Sub Form_Active()
Yes, you can.
You must open the card there too.
Private Sub Form_Activate() Dim i As Long Dim n As Long OpenDevice (0) i = ReadAllDigital If (i = 1) Then n = 1 ElseIf (i = 3) Then n = 2 Else n = 0 End If WriteAllDigital (n) End Sub
i have now this codec but it does nothing only making connectie Option Explicit
[code]Dim DoNothing As Boolean
Dim n As Integer
Private Declare Function OpenDevice Lib “k8055d.dll” (ByVal CardAddress As Long) As Long
Private Declare Sub CloseDevice Lib “k8055d.dll” ()
Private Declare Sub WriteAllDigital Lib “k8055d.dll” (ByVal Data As Long)
Private Declare Function ReadAllDigital Lib “k8055d.dll” () As Long
Private Sub noodstop_Click()
Dim i As Long
Dim n As Long
OpenDevice (0)
i = ReadAllDigital
If (i = 16) Then
n = 128
End If
WriteAllDigital (n)
End Sub
Dim i As Long
Dim n As Long
OpenDevice (0)
i = ReadAllDigital
If (i = 1) Then
n = 1
ElseIf (i = 3) Then
n = 2
Else
n = 0
End If
WriteAllDigital (n)
End Sub
Private Sub Form_Load()
MsgBox “welcome to my first k8055 program”, , “welcome”
End Sub
Private Sub Connect_Click()
Dim CardAddress As Long
Dim h As Long
CardAddress = 0
CardAddress = 3 - (Check1(0).Value + Check1(1).Value * 2)
h = OpenDevice(CardAddress)
Select Case h
Case 0, 1, 2, 3
Label1.Caption = “Card " + Str(h) + " connected”
Case -1
Label1.Caption = “Card " + Str(CardAddress) + " not found”
End Select
End Sub[/code]
Call the OpenDevice(0) only once.
This is done in the procedure Form_Activate().
This program works fine.
If you activate input 1 or input 1 and 2, when you close the message box, the outputs are activated: LD1 or LD2 is lit.
If you activate input 5 and press the noodstop button then the LD8 is lit.
[code]Option Explicit
Dim i As Long
Dim n As Long
i = ReadAllDigital
If (i = 16) Then
n = 128
End If
WriteAllDigital (n)
End Sub
Dim i As Long
Dim n As Long
OpenDevice (0)
i = ReadAllDigital
If (i = 1) Then
n = 1
ElseIf (i = 3) Then
n = 2
Else
n = 0
End If
WriteAllDigital (n)
End Sub
End Sub[/code]
this is my code and its doing nothing
Dim i As Long
Dim n As Long
i = ReadAllDigital
If (i = 16) Then
n = 128
End If
WriteAllDigital (n)
End Sub
Dim i As Long
Dim n As Long
OpenDevice (0)
i = ReadAllDigital
If (i = 1) Then
n = 1
ElseIf (i = 3) Then
n = 2
Else
n = 0
End If
WriteAllDigital (n)
End Sub
End Sub
[/code]
and if i at this code and the noodstop button in the demo software it isnt working and i have renamed it to noodstop and the caption also
Private Sub noodstop_Click() Dim i As Long Dim n As Long i = ReadAllDigital If (i = 16) Then n = 128 End If WriteAllDigital (n) End Sub
I do not see any problem in the code.
It reads the digital inputs and activates the digital outputs when button “noodstop” is pressed.
Maybe you have to add a label to display what is read from the digital input.
Add:
Label1.Caption = CStr(i)
Private Sub noodstop_Click() Dim i As Long Dim n As Long i = ReadAllDigital Label1.Caption = CStr(i) If (i = 16) Then n = 128 End If WriteAllDigital (n) End Sub
if i push inpout 1 or 1and2 its doing nothing if i push noodstop the label caption change to 0
The button procedure is activated [color=#FF0000]only [/color]by the noodstop button.
It does nothing if the buttons of the K8055 are pressed.
If you push input 1 or 1&2 [color=#FF0000]and [/color]push noodstop then you should see the input data value:
“1” or “3” in these cases.
You have to use timer to read the K8055 status in real time.
now i get it the timer is to read the k8055 on every interval so i need to set the noodstop also in the timer to make it al real time button
i need to make this in the timer code but how
Private Sub Timer1_Timer() Timer1.Enabled = True Dim i As Long Dim Data1 As Long Dim Data2 As Long Dim n As Long OpenDevice (0) i = ReadAllDigital If (i = 1) Then n = 1 ElseIf (i = 3) Then n = 2 elseif (i = 16 'or noodstop.click) Then n = 128 Else n = 0 End If WriteAllDigital (n) i = ReadAllDigital Timer1.Enabled = True End Sub
and if noodstop is active or inpout 5 it need to be above everything so if inpout1 is true and noodstop is true it need to be noodstop
First comment:
Do not put the OpenDevice (0) to the timer function.
Put the OpenDevice (0) to a separate “Open” button function.
How to check if the noodstop button is pressed?
  • You can use a global variable and set it with the noodstop button.
  • Check this variable in the timer routine. If true then do what is needed to do…
Change the first
to
Timer1.Enabled = False
The second “Timer1.Enabled = True” at the end is OK.
i im done whit it here you see the working code
Dim n As Integer
Private Declare Function ReadAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long) As Long
Private Declare Sub ReadAllAnalog Lib “k8055d.dll” (Data1 As Long, Data2 As Long)
Private Declare Sub OutputAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long, ByVal Data As Long)
Private Declare Sub OutputAllAnalog Lib “k8055d.dll” (ByVal Data1 As Long, ByVal Data2 As Long)
Private Declare Sub ClearAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub SetAllAnalog Lib “k8055d.dll” ()
Private Declare Sub ClearAllAnalog Lib “k8055d.dll” ()
Private Declare Sub SetAnalogChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub ClearDigitalChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub ClearAllDigital Lib “k8055d.dll” ()
Private Declare Sub SetDigitalChannel Lib “k8055d.dll” (ByVal Channel As Long)
Private Declare Sub SetAllDigital Lib “k8055d.dll” ()
Private Declare Function ReadDigitalChannel Lib “k8055d.dll” (ByVal Channel As Long) As Boolean
Private Declare Function ReadCounter Lib “k8055d.dll” (ByVal CounterNr As Long) As Long
Private Declare Sub ResetCounter Lib “k8055d.dll” (ByVal CounterNr As Long)
Private Declare Sub SetCounterDebounceTime Lib “k8055d.dll” (ByVal CounterNr As Long, ByVal DebounceTime As Long)
End Sub
Private Sub noodstop_click()
If noodstop.Caption = “NOODSTOP” Then
Dim i As Long
Dim n As Long
OpenDevice (0)
i = ReadAllDigital
n = 128
WriteAllDigital (n)
noodstop.Caption = “LOCK”
Else
If noodstop.Caption = “LOCK” Then
End If
End If
End Sub
Dim i As Long
Dim Data1 As Long
Dim Data2 As Long
Dim n As Long
OpenDevice (0)
i = ReadAllDigital
If (i = 16) Then
n = 128
Else
If (i = 17) Then
n = 128
Else
If (i = 18) Then
n = 128
Else
If (i = 19) Then
n = 128
Else
If (i = 1) Then
n = 1
Else
If (i = 3) Then
n = 2
End If
End If
End If
End If
End If
End If
WriteAllDigital (n)
i = ReadAllDigital
End Sub[/code]
Congratulations!
Some comments about your code:
You are calling the [color=#008000]OpenDevice (0)[/color] in the timer routine. This is not a good practice.
Call the [color=#008000]OpenDevice (0)[/color] only once at the beginning of the program.
You may put it to the [color=#008000]Form_Load() [/color]function.
Also add this code to close the connection to the K8055:
Private Sub Form_Terminate() CloseDevice End Sub
Here the slightly modified code:
Dim n As Integer
OpenDevice (0)
End Sub
CloseDevice
End Sub
Dim i As Long
Dim n As Long
i = ReadAllDigital
n = 128
WriteAllDigital (n)
Else
End If
End If
End Sub
Dim i As Long
Dim n As Long
i = ReadAllDigital
If (i = 16) Then
n = 128
Else
If (i = 17) Then
n = 128
Else
If (i = 18) Then
n = 128
Else
If (i = 19) Then
n = 128
Else
If (i = 1) Then
n = 1
Else
If (i = 3) Then
n = 2
End If
End If
End If
End If
End If
End If
WriteAllDigital (n)
End Sub[/code]
