Hello ,
I have a problem with the K8055!
I want to have a DC motor right and left turn.
But DC motor rotate only one direction.
How can I find solving these problems?
Thank you for the help.
Okan
Hello ,
Okan
You can use H-bridge circuit for the DC-motor.
Here is an example how to do it:
Warning: Never turn O1 and O2 outputs on (low) simultaneously!
Sorry if i ask something stupid,
For my project i need 3 motors to be able to run in both directions?
So Motor 1 left/right, so for motor 2 and 3
Or any other solution?
Thank you, all input is welcome
You can use this circuit only for low current DC motors.
[quote]1. I have the same kind of problem, what kind of transistor can be used for Q1 and Q2.[/quote]The specified maximum current to the K8055 digital outputs is 100mA.
There is a lot of transistors available for this current (e.g. 2N2907A).
[quote]2. Can the batt as shown in your example be 12v or must it be limited to 5v.[/quote]Yes, 12V is OK too.
[quote]3. Can this kind of H-bridge be used for somewhat larger 1.5Amp DC motors, or is it better to work via relais?[/quote]If you like to use higher current motor then using the relays is the best choice.
Thanks for your input.
I’m building a ROV and use only Velleman modules/kits. Will let you know when the projects is finished.
Marc
I wish success to your project.
Please write this your mail… and I contact you… because I have small problem for you… sorry my english is not goog because I´am from Czech Republick
Please post the description of your problem to this forum.
The purpose of the forum is for Velleman Project users to help each other and to exchange useful information.
