K8055 Analog Output not quite +5v
I get +4.75v from the analog output. From reading the forum this is correct. Can it tweak it up to 5v? Or can I add somthing on the output to get it to 5v?
Using a self powered USB HUB you may get slightly higher voltage out.
See this thread for some test results: viewtopic.php?f=3&t=4265
Even better if you can get an adjustable power supply. You may set the supply voltage of the HUB to maximum allowable value of 5.25V.
If you need only +5V out you may add a pull-up resistor from the analog output to the +5V.
Adding this resistor causes increase to the low level of the analog output.
