Hi All,
I am looking to purchase a IR receiver kit - Velleman K8050 15 Channel Infrared Receiver Kit.
I would like to get peoples professional advice on if the following will work with this device.
I am planning on using the module to allow me to create IR signals that can be learned that will control buttons on a RF remote directly. All in one single RF remote currently controls all of my light switch plates through my house.
Looking to hook these lights up to SQ blaster system and have full control of lighting system through iOS devices like iphone, ipad etc.
The only way to make the light switches compatible is to somehow create IR signals to control the lights. the following post is a basic outline of what some other people have done to RF remote controlled items to sync with IR remotes etc.
Do you think its possible to do something similar with the Velleman K8050 15 Channel Infrared Receiver Kit on the following RF remote that controls teh following type of switch plates:
avsforum.com/t/1300232/ir-co … rf-devices
REMOTE (Livolo)
VL-RMT01
livolo.com.tr/products9.asp -
LIGHT WALL SWITCH PLATES (Livolo)
livolo.com.tr/products6.asp
If this is possible how many channels would I need?
The remote is setup so that you press a number room you would like to control (ROOM 1-4) and then press the number light that is programmed to it (LIGHT 1-9). numbers 7 & 9 are only available to control dimming switches. that means that you are only allowed to use 2 dimming switches per room on this remote. Each dimmer number (7 & 9) has a + & - button to control level of dimmer. I can setup house so that i have two RF remotes wired and programmed to these remotes allowing me a total of 8 rooms. i just need to know roughly how many channel IR receivers i will need for this? i know it will be dependent on how many lights and switches etc but if you can give me a rough indication on exactly what a single channel can support then i can calculate the amount.
Or do I just need amount of channels as per the amount of buttons I will be pressing on the RF remote to control the switches/lights? If I work out that I will be using buttons 1-9 and ROOM1-4 and SCENE 1-4 as well as the ALL ON/OFF button for each of the two remotes, then i could safely say that i would need maximum 54 channel IR receiver or 4 of the Velleman K8050 15 Channel Infrared Receiver Kits. Is this correct?
