k8048
How can I programing PIC16F627 with k8048 programmer? I am aboslut beginner
I get the message “THE SETTINGS DON’T MATCH THE PIC IN THE PROGRAMMER” when using the PicProg2006 (v2.0.2.5) software with the VM111 (ie K8048) programmer. This is with the PIC16F627 microcontroller shipped with the module installed in the programmer. Could You give me any advise?
For the K8048, the ProgPIC2 software must be used, you can use the PicProg2006 software when it is set to the K8048 compatibility mode.
Futher check your power supply (min 15V to the PCB) and the cable, these one must be full connected (pin to pin).
