K8048 / VM111 kit: PIC can no longer be accessed
Hi guys,
I’m new to PIC programming and to Assembly so bear with me please; I recently bought a kit which comprised the Velleman VM111 programmer and P16F627 and tried one of the demo applications which came with the software, and a couple of simple programs I adapted from online to learn assembly, which worked fine. I then adapted a sample program from a basic tutorial, assembled it with MPASM and wrote it to the microcontroller with Progpic2, and it worked… but somehow progpic2 can no longer communicate with the μc, so I can’t change the program, or even remove the program from the device. I’m totally stumped as to why, as I’ve also double-checked the configuration in progpic2.
I’ve since been advised by the creator of the tutorial that since I used the config settings he specified in his tutorial before changing them to the defaults given in the demo applications as seen in the code below, some poorly-designed programmers are unable to enter programming mode when the PIC’s internal oscillator is activated. Is the VM111 one of them?
The code I used:
;Hello chip program, adapted from http://www.winpicprog.co.uk/pic_tutorial1.htm.
	LIST	p=16F627		;tell assembler what chip we are using
	include "P16F627.inc"		;include the defaults for the chip
	__config _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _XT_OSC
	cblock 	0x20 			;start of general purpose registers
		count1 			;used in delay routine
		counta 			;used in delay routine
		countb 			;used in delay routine
	endc
	org	0x0000			;org sets the origin, 0x0000 for the 16F628,
					;this is where the program starts running
	movlw	0x07
	movwf	CMCON			;turn comparators off (make it like a 16F84)
   	bsf 	STATUS,		RP0	;select bank 1
   	movlw 	b'00000000'		;set PortB all outputs
   	movwf 	TRISB
	movwf	TRISA			;set PortA all outputs
	bcf	STATUS,		RP0	;select bank 0
Loop
	movlw	0xff
	movwf	PORTA			;set all bits on
	movwf	PORTB
	nop				;the nop's make up the time taken by the goto
	nop				;giving a square wave output
	call	Delay			;this waits for a while!
	movlw	0x00
	movwf	PORTA
	movwf	PORTB			;set all bits off
	call	Delay
	goto	Loop			;go back and do it again
Delay	movlw	d'250'			;delay 250 ms (4 MHz clock)
	movwf	count1
d1	movlw	0xC7
	movwf	counta
	movlw	0x01
	movwf	countb
Delay_0
	decfsz	counta, f
	goto	$+2
	decfsz	countb, f
	goto	Delay_0
	decfsz	count1	,f
	goto	d1
	retlw	0x00
	end
The error I keep receiving:
Naturally I’ve made sure the programmer’s set to program mode, the PIC is securely in place, and I used a program which previously worked fine (and made sure the config settings in progpic2 were correct).
Any help solving this problem would be greatly appreciated.
