K8048 "The setting dont match the PIC"
I have received this error when using the 8048 kit with the 16F627 it came with. When I select PIC16F and type 16F627 and press Read I get this error.
Searching previous post in this forum this error seems to be associated with using a usb-serial convertor. Howver I AM NOT using one of these; my PC Motherboard uses a Intel 82801 Southbridge controller with conventional COM1 addressing via Port 03f8h.please can you explain what the problem is ?
I just realized this morning (nearly 2:00 am), that a PIC supplied with Velleman’s VM111 board (K8048) is NOT the mentioned PIC 16F627, but 16F829 instead. With this setting it works fine.
However, Velleman could spare me a long night (would have been sleeping, instead of searching this problem), but such is life…
:slight_smile:
István
(Hungary)
If PIC16F829 is not in the list.
The only PIC that is supplied is PIC16F627 (normal version, not A).
16 F 819, sorry.
(Unfortunately text on top of the PIC is hardly readable.)
