If I test the kit with a bulb it works correctly.
I connect a transformer (various: block or ring typ) the LED 1 shows fault code 8 (“load to inductive”).
According to the manual this kit K8028 is suitable to connect a transformer for halogen lighting for example.
I tested a condenser in the circuit.
If the capacity-value approximates 10nF there is no fault code, but also no voltage (Usec) at the transformer.
What can I do to connect a transformer (Uprim 230V, Iprim 250mA)?
I use function no.5 (slow on/off).
=> How many transformers I should test? (5, 10, 50…?)
Please tell me first wish type of load (lamp’s), transformer, transformer power, lamp power you are using.
Don’t put extra components in the circuit otherwise the measurment timming will not be correct.
Test first with a 60W normal lamp, check if this works perfectly.
I’m using a Paulmann and EREA transformer w/o any problem.
