K8015 Relay Overide
I want to manually activate relay RY1 by installing a spst switch from transistor T1 collector to ground. When the switch is closed the relay will energize. I don’t think this will damage IC1 or T1.
Do you think I am safe doing this?
Should not be a problem.
