I have the Battery Charger K8012 completed, but now I want to use it in combination with my solar panels.
Specifications of the solar panels : Rated Voltage Vmpp 35V, Configuration 24V, Rated Current Impp 3,15A.
Normally it is done with a Charge Controller. The Charge Controller keeps the voltage given by the solar panel on the correct level.
Probably when I use the Battery Charger K8012 and a DC-DC convertor, instead of a AC transformer it will work also.
Question : where do I have to connect the DC-DC converter and what are the specifications for this unit?
Best regards
Dear sir,
Velleman can’t give any sugestions about a combination from this kit with a solor panel.
Can I use 1 transfo for multiple (perhaps 10x) battery chargers?
Best regards
Theoretically, this is possible but not recommended.
