K8012 R6 Value
I have just been assembling K8012 (intelligent lead acid battery charger) and have found that R6 as supplied in the kit is 100K but the circuit diagram indicates it should be 270K - which value is correct?
Partlist values are correct. Diagram values are subject to changes.
The parts list in the manual also states this should be R6 270K so could you confirm which is correct - is R6 100K as supplied with the kit, or 270K as in the parts list and circuit diagram?
270K should be the correct value. Should you wish to receive the correct part by mail, please let us know your address. We are sorry for any inconvenience.
No problems - I think I can run to supplying my own resistor :lol:
Thanks for getting back to me.
Purchased the kit last saturday 17 november 2007. Found the same problem: R6 in parts list and diagram 270k, supplied 100k. Thanks to this topic installed 270k. Charger works now perfectly!
Sorry for this inconvenience. Wrong part is probably caused by human error. We will look into this. Thanks for reporting it.
