K8008 - Multifunction Mains Powered Relay Timer Module
I am looking for a module to replace a mains powered and mains switched timer-off pump run on circuit, K8008 - Multifunction Mains Powered Relay Timer Module is obviously mains powered but from what I can tell it is not mains switched ? Could you confirm I have understood correctly and if possible suggest any other product you may have that either does as I need or that can be added to K8008 to convert the mains switching to a level suitable for the board. Thank you.
Sorry, we do not quite understand. Please elaborate.
