I have a electric water pump for cooling a car engine. At the moment it is running directly from 12v supply. I believe it is running too fast and want to half it’s running speed. I have just bought the 8004 kit.
I have a couple of questions ( i know very little of electronics!)
I have yet to measure the power in amps whilst it is running at 12vdc the kit is rated at 6.5a. if running power is close to this will it be ok? will the starting spike of current damage it?
is there any way of uprating the kit to, say, 7.5a?
will i need a external potentiometer to adjust speed? if so can you suggest specs?
Testing will reveal if the kit is suited, as there are a couple of issues:
Running it close to the max. specs could prematurely trip the protection circuit.
The unit is equipped with a soft start circuit, which might need adaption with certain loads.
