K8004 - how to control output current?
How can I adjust the maximum output current on the K8004?
I have connected a DC motor and it shuts off at 0,35 A (at 24 VDC input).
Thank you for your help!
You can download the manual from this link.
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k8004.pdf
On page 8 they show 3 different ways to control the output.
The easiest would be figure C
[quote=“Wrong Way”]You can download the manual from this link.
The easiest would be figure C[/quote]
There I control the speed of the motor, right?
I am looking for how to adjust the output current.
It shuts off at 0,35 A.
Either there is an assembly problem or the load has a too high inrush current (halogen lightbulb, electric motor, etc…).
Basically, the resistors R8, R9 and R10 measure the current. By lowering the total resistance, you can make the unit less sensitive to high inrush currents.
