K8001 communication problem with k8000 or computer
I obtained the kits k8000 and k8001 microcontroller. They respond correct at the individual prescribed tests as written in the manuals.
After connection the k8000 and k8001 the entire responds however not well at the example programs such as runlight.scr or the other programs with the .src extension. By reading via Transmit - Program the led from the k8001 microcontroller doesn’t flash and I obtain the message “Verify Error”. I therefore use an old 386 computer with windows 3.11.
The clearing of the memory works now and then (in that case the led flashes and the computer gives a confirmation), most of the times after I have disconnected the power for a longer period.
What goes wrong? The test is like the chapter in the help function how to use the controller. Who can help?
After using individually shielded cables between k8000 and k8001 the communication is ok.
