K6501 remote control by telephone kit
What is the meaning of the -switch- function on the circuit board?
What can you do with this switch function??
When you close these contactteminals the green led wil be activated.
This allows you to check by phone if a contact is open or closed, e.g. you can connect a mechanical contact to a door and check from a remote location if this door is open or closed. You always hear 4 tones when you call the unit. The first tone gives you the status of the switch, the 3 following tones is the status of the 3 relay outputs.
