K5600
:frowning: I am having trouble with doing the K5600R kit. It says a shunt can be made by making a short circuit soldering point at the unused LED positions. Can anyone help please, it would be much apprieciated.
This is correct. It is unclear to us what your exact problem is. Please elaborate.
I think he means where you solder the leds. If you don´t use a led,
you must bridge the connection where the leds go. He would like know how to solder the connections with just solder.
It is just a matter of shorting the led-pads at the solder side by means of a drop of solder. It is a lot faster than inserting a wire jumper for each led…
