i’ve recently made a k5201 light computer. when testing, the leds all glow up in different patterns as they should, but the lights i wanted to use do not glow up in patterns, the light up one by one and then stay on…
i use 2 different transformators for this, what could be the problem?
Can you please give more details ?
What kind of lighting did you hook up to the unit ?
Does the unit still work when you remove the lights ?
i have hooked up small 3V glow lamps out of small elecktronic toys, they work good, and they are free
and the unit works good, the leds work normal, unlike the glowing lamps…
the leds work regarldless of the glow lamps, if theyr hooked up they work, if they are not, then they work also…
the problem is really the extra lamps…
Please note that the K5201 has TRIAC outputs.
These are only suited to drive 110/230VAC lightbulbs.
oh, didnt knew that…
well thnx for the info…
but can i use leds or something? i really need small lights, not to bright to.
