I have assembled the kit and tested as per instructions. Is it normal for the yellow LED to come on when first switched on the dim? The tests for left & right speakers both passed using the red / yellow LED`s. With the unit turned on I tested the the continuity of the PA & SP from the relays I get feed through the left relay but nothing through the right relay.
Best regards, Mick.
