I’m building a triple channel amp with completely independent power supplies (floating ground) using quad 405II/III boards (each channel output consists of Channel+ / ChannelGround where ChannelGround is independent of the other channels) and want to add K4700 speaker protection. I already bought two kits intending to use only half of the second kit for the third channel, but I see that the - is shared ground on the K4700 so I loose my channel independence.
What would the correct connection be for such a setup?
Many thanks for your help.
On second thoughts I should be more specific:
Each channel ground is based on the centre tap of its respective transformer, which is also grounded to chassis (and mains ground) through the following filter:
Chassis ground_ -diode+ _ Transformer centre tap
Chassis ground _ +diode- _ Transformer centre tap
Mains ground _ Chassis ground _ 10R resistor _ Transformer centre tap - Channel ground
Chassis ground _ 100nF cap _ Transformer centre tap
Similar to the earth/ground arrangement here:
