Question regarding connections:
English instructions, page 8, #12. Use and connection:
“Connect the L connection … when the lights are turned on.”
“Connect the C connection … when the contact is switched ON.”
Please clarify. It sounds to me like these are identical. Does C connect to the line or load side of the headlight switch?
Thank you.
Is it a terminology question? I’m in US. Does “Contact” = Ignition switch?
Hi Neo,
Yes the contact does mean the ignition or any place that voltage is present after the ignition is in the on position.
This will let the K3505 know when the car is on.
L should be connected to the load side (headlight side)
This will let the K3504 know when the lights are on.
Glad to be of assistance.
Enjoy your kit.
