K2636 output
I’m only getting 0 to 9 volts A/C output…what am I doing wrong? I’m confused about how to connect power to the board…in phase/out of phase?
finally figured it out… F2 had a bad connection in it. It wasn’t blown but wasn’t making a connection. I stood the fuse up on the work bench and placed my soldering iron on the bad end with some solder and it resolder the link inside well enough for testing and solved the problem. I never checked the fuse because it didnt look blown. I’m disappointed that no one from Velleman never gave me any direction on this.
Two things:
First: Sorry, but we do not have the means to answer immediately, sometimes it might take a couple of days.
Two: We have to assume that no assembly mistakes are made and that obvious things like the fuse are OK, so I doubt we would have figured that the fuse connection was bad, what are the odds?
Anyway, happy to read it works fine and sorry for the bad fuse.
