I want to drive a K2634 from a ULN2803 on a custom logic board. Can I use a single K1823 to power both the K2634 and the logic board without interference?
Jack
Jack
NO, this is not possible.
K2634 is connected to the mains, so power supply must be isolated !
So I need to use two K1823s and two transformers to provide the required isolation? I now see that one side of the K2634’s low voltage is connect to main.
You need two transformers.
K2634 does not need K1823, unregulated DC is fine…
