I’m new and I am a novice in electronics too.
I would like to use a K2633 for a project to shunt some sensors and motors when they are unused.
However, I didn’t find a technical data-sheet which explains, how inputs it needs, which signal and tension, intensity it needs, if the relays can be separatly controlled… To put it in a nutshell, I would like to know how it works, and how I can connect it with an Arduino board.
Thank a lot in advance!!!
Regards
The relays on the K2633 can be controlled individually.
It’s been awhile since I messed with mine but I think you have to ground each input to activate the relay.
You can download the assembly manual here. http://www.vellemanusa.com/support/downloads/?code=K2633
[quote=“Wrong Way”]The relays on the K2633 can be controlled individually.
You can download the assembly manual here. http://www.vellemanusa.com/support/downloads/?code=K2633[/quote]
Thank ! However, there is no electrical diagram. So I don’t know how many inputs and outputs it uses…
