K2625 werkt niet
The kit K2625 Tacho doesn’t work on the bike it has bin tested and tuned ,works very wel after mounted on my bike there seems to be a problem ,the display works but no rev display .the connections are oke the puls connection is on the right site of the ignition coil.
my bike has a full transistorized ignition using a puls generator.
The question is what to do to make the tacho work.
Christianvtx
Unit needs +12V pulses in order to operate correctly. Check if this is the case.
