I assembled the timer and it times perfectly except there is no output from the relay. The relay clicks but there is no current passing to the outputs.
-I am powering it with a 12v battery. -I am using the circuit to control a 9v electric motor.
Why is there no current?
There is no current because the kit is working perfectly normal. A relay output is a contact, there is no voltage coming out of a contact.
How do I get it to turn the 9v motor on and off?
Wire the relay contact as if it were a switch in series with the motor…
