When i press ‘start’ the relay closes
when timer runs out, and when ‘stop’ is pressed, relay will not open.
When measured:
when timer started, the voltage on the relay is 12 volts,
when timer stopped, the voltage on the relay is 7 volts and that is probably why the relay will not close.
The problem is that i don’t know why…
I have tripplechecked the position of every element on the circut board.
What could be the problem?
