K2579 modification?
Is it possible to modify the K2579 timer unit so that it does a single cycle with the start button continuously pressed?
I have an application where I need to output ON when power is applied to the time unit so the output goes OFF after the set time of the timer
and does not come back on until power is cycled to the timer again.
I tried using the relay as the Start signal but the time goes back through the cycle when the relay drops out after the time has expired.
Not really.
A better and more reliable option would be MK188.
http://www.velleman.eu/products/view/?id=408232
