Hi all
I am looking for a way of getting a delayed “on” command to run the fan on an external oil cooler (the fan circuit currently runs from a 12v+ ignition switched live, to a relay that starts the fan).
What I would like to do is to start the fan 2-3 minutes after the ignition is turned on (to remove the fan load from the battery while cranking the engine to start)
Could the K2579 kit be modified to do this? Perhaps by wiring the “on” switch to be permantly on?? Thereofre switching the ignition on, autimatically starting the “count down”?
Would there be a better product to use?
Your thoughts would be appreciated
Mark
