I would like to fit the ignition amplifier kit to my 1972 Volvo ES. Howver, the car has a tachometer wired between the coil and the points - exactly where the igniton kit should go. How can I install the Velleman kit and keep the tachometer working?
Many thanks
Tim[/quote]
Connect the kit up as instructions. use a piggyback connector on -ve side and connect tacho to that [unless you’ve got a spare terminal in which case forget the piggyback].
