If correctly installed and used, the unit does not need extra protection.
A couple of questions:
What is your application?
Voltage?
Current consumption?
and hook-up then we can take a look and provide some feedback.
Application ; in an ancien car with 12volts standart ignition, cap removed to install the K2543.
Current… don’t check this one, have to do then.
No troubles for pictures, I don’t need for this time, I don’t have the unit here in this moment.
[quote=“VEL417”]If correctly installed and used, the unit does not need extra protection.
Voltage?
and hook-up then we can take a look and provide some feedback.[/quote]
