K-8056, where to find program example file
I have just built the K8056. Everything is working fine using Velleman software to control it.
I’m new into RS-232 and need the program example file. Refer to manual page 11.
I can’t seem to find it on your web site. Where can I find it?
You can find this example at our website, “click downloads”
Link:
velleman.be/downloads/files/ … b_demo.zip
I’m sending this HEX string from a Philips Pronto TSU-9600 and RFX9600 extender to K-5086:
0D 31 53 31 6E
Settings:
2400/8/N/1, repeat 3 times, time between repeats 30ms.
When using the provided Relay-card program everything works fine. But I can’t get the card to respond when using the Pronto. The extender indicates transmitting signal on the selected RS-232 output.
What is the card address ?
Which relay would you like to operate ?
What command are you using ?
This info will allow us to compose correct string
It was my mistake!
Hex code, card 1, relay 1, On: 0D 01 53 31 6E.
I also figured out how to toggle and reset the relay.
But I don’t know how to make a momentary function.
Which instruction to be sent?
Hi, ampere,
i have the same problen here
i,m trying to get the K8056 working with a philips pronto TSU9600
cant seem to get it working with the ascii codes
is it possible that you send me the
pronto file that controls this card ?
my email adres is fvw_75@hotmail.com
hope to hear from you
(edit)
found the problem …
all hex codes work … only on serial output 4 (green connector)
