It works fine, i can switch on three differnt heaters by phone.
Do you know if it will work if I subsribe a ADSL + phone contract (Free or Tele2) ?
Shall i connect the K-6501 phone plug after or before ADSL Box ?
I am afraid If the signal is full numéric the K-6501 won’t recognize it ?
K6501 only works with analog PSTN line. If the signal is 100% compatible with a classic PSTN line, it will probably work. We have no experience with this matter. You will have to give it a try.
i have NO experience of this switch and am complete newbie, but i would guess the unit uses DTMF tones, if that is the case, you should connect the unit to the telephone side of the ADSL microfilter.
maybe that was not your question, in which case, please accept my apoligies.
