I have built two of these kits, one for my car and one for my son’s. I have just fitted the first and the time between activations is far quicker than you state, the effect is that on the slowest setting wiper runs continuously although you can hear the relays switch on and off about twice a second. Assunming it to be a fault with one of the kits I have fitted the other and it too switches at the sme rate. Please advise what can be done to get back to the stated intervals?
Make sure to check all resistors and cap values.
A wrong resistor or cap value will influence timing.
Thank you for your response. I have checked the values against the circuit diagram and found no errors. I am attaching a link for photos of both sides of the board as follows imgur.com/a/snI8s I trust this will help you idetify the issue and get back to me with how I can get the correct intervals.
As far as we can see, assembly looks OK, so at this time, we do not know why it behaves this way.
Do the kits behave this way when the wiper are not connected to the relays?
Very strange.
The part that is responsible for the timing is C2.
You could experiment by increasing its value until the desired timing is obtained, or you can return both kits for inspection.
After checking with repair dept, they informed us that your items have been treated last week.
Both units have been mailed to your address and should arrive soon.
Problem was solder related.
Thank you for the return of these, I have refitted it to the car and had exactly the same problem, coincidently my son was in the process of changing over the facet fuel pump and as soon as he disconnected it the wiper unit started to work properly. I can only assume that the issue was related to the soloniod operation of the fuel pump as it now does 15, 10 and 5 second intervals as it is meant to do.
Thanks for your help with this, please advise, if you know, what needs to be done to avoid the interferrance, would a capacitor across the pump work?
