Installation-disc for PCS32?
Hello,
I used a PCS32 for long times, but not in the last 5 years. Now, when I tried to install it again on an older handheld with DOS, I found my disk not readable. All trials to refresh it didn´t work.
Velleman seems to have no software for this old PCS in the service-programm. I would prefer to work with this old part, yes, and under DOS.
Can anyone help me?
Greetings from Germany
Fritz
Hereby a link to the software.
Careful: link will be active for 7 days.
http://downloads.velleman.be/3ad158bbe62b988651c24444404d293b/DSO3.zip
Very quick reaktion!
Thank you very much!
Fritz
Same problem here.
IIRC my version was the DOS version of the PCS32 Software (Storage Scope For PC).
Can you provide a download link?
As a side note: do you know of any USB2Parallel converter so that I can use the digital scope from my Laptop (using dosbox)? As an alternative could you provide the parallel communication protocol?
Thanks
Mirko
Hereby a link to the windows software:
velleman.eu/images/tmp/WinDSO_FG32_v123.zip
Please note that a USB to parallel converter does NOT work with this item.
Hello, and thank you for the quick reply.
I’d like to have a link to the DOS version as well (I’d prefer to work with the DOS version, if possible).
Any chance to also have the docs about the protocol so that I can, as an example, interface the PCS32 with an Arduino?
Thanks and happy new year!
Mirko
Anyone have this DSO3.zip file>?
Thanks.
@simba ,
See topic: K7103 Sofware and Info - Instruments / PC Oscilloscopes and Recorders - Whadda forum - Community Help and Support
